跳转到主内容
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
308 个问题 查看全部
How do I fix the open tray problem?
On the drive that I'm working on, the laser will light up, and when I load both game and movie discs it will spin for 1-2 seconds then stop and say, "Open Tray."
I have the drive open right now, and I've already cleaned the laser with rubbing alcohol and a couple cotton swabs, but that didn't fix it. I also blew out the drive thoroughly, and manually removed some dog hairs that had accumulated in the drive. So far I've had no luck figuring this one out.
I just tried manually re-positioning the laser, but it just goes back to its normal spot near the spindle motor every time.
I'll order a new laser, but hopefully I can do this without one.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
You will probably need a whole new DVD drive
Be careful with this, the 360 drives were keyed to each motherboard, thus you need to solder the old board in the new drive, so it may have that issue for you, don't know about a 360 S yet, i may test this on a 360S if i get a dead one given to me and reflow and use a unmodified DVD drive, see if sees the drive
You should try the laser first, so you can try and get it working without soldering the old board in the new drive
I would strongly recommend swapping controller boards so you don't get banned from xbox live and it sees the drive is different from what is coded in the firmware
这个答案有帮助吗?
得分 0
1条评论:
xbox 360 S drives are also paired to the console. some models are even impossible to hack. so a drive board swap is required
完成的
添加一条评论
最有帮助的答案
More than likely, it just needs the laser replaced. This has been the case for 99% of the consoles I have repaired. There will be times when it is more than the laser, but for a few bucks you can start with replacing the laser.
这个答案有帮助吗?
得分 1
1条评论:
what kind of laser replacement do you get for a Xbox 360 Slim
完成的
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vadr64 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 36
总计 10,466
