跳转到主内容
Vavle 公司于 2022 年 2 月 25 日发布的游戏掌机。
256 个问题 查看全部
My charger is not charging my steam deck light will not even come on..
Hello, I've had my steam deck for about a year and a half and was trying to play it the other day I hit the power button and nothing. when I plug in the charger that came with the deck the light doesn't even light up to signify that it is charging. I already tried basic trouble shooting from YouTube and steam deck support and unfortunately nothing. I even tried a different charger like the nintendo switch or just a usb c android charger. I am pretty certain my usb c charging port is busted. Has anyone else ran into this problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Believe it or not there’s also a whole page full of things for Steam Deck No Power Troubleshooting, but sounds like you may be right.
Does the charger seem wiggly? If the port is the problem, that could be a tricky repair because it’s soldered to the motherboard. I would check to be sure the port is clear first, could be some debris stuck. But if not, then charge port is a totally realistic cause for this.
It’s fixable, but you’d want some soldering experience under your belt before undertaking it yourself. There might be a local repair shop that could do it though.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
MaurinoLopez@hotmail.com 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 50
过去 30 天: 181
总计 902
