跳转到主内容
2018年7月发布,15英寸 MacBook Pro,型号 A1989,拥有True Tone技术的LED背光15.4英寸显示器,最高6核心的酷睿 i7 处理器。
206 个问题 查看全部
What battery for a May 2018 MacBook Pro A1398?
I'm trying to find the replacement battery for my May 2018 Macbook Pro with Retina Display (https://support.apple.com/kb/SP776?viewl...)
I've searched the forum and can find plenty of reference to model A1398 but not from 2018 and I read the batteries are not all compatible due to differing chemistry. I'm finding this model particularly difficult to nail down as even on here it lists 2018 models as released after May, so I suspect this is not correct also.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Are you sure of the model number and the year?
MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery图片
产品
$79.99
MacBook Pro 15" Retina (Mid 2018-2019) Battery图片
产品
$119.99
MacBook Pro 15" Retina Display Mid 2012 电池图片
指南
2012年中期视网膜屏Macbook Pro 15''电池替换教程
难度:
困难
1 - 2 hours
MacBook Pro 15" Touch Bar 2018 电池图片
指南
2018年带 Touch Bar 的15寸 MacBook Pro 电池更换
难度:
困难
1 - 3 hours
这个答案有帮助吗?
得分 1
2条评论:
Perhaps you're right! I looked up the warranty coverage and it shows Macbook Pro Retina Display 15", Mid-2015 but PURCHASED in May 2018. So That should narrow it down a bit for battery. It should be MacBook Pro 15" Retina (Mid 2015) Battery
however the model number is definitely A1398, which is still a bit confusing perhaps?
完成的
@jordanv42154 - Apple loves to confuse! One has to be careful to look beyond the model number as just like a Ford Mustang fro 1992 to todays are sizable differences! As you can see there are even two versions within this years series!
> A1398 IG
> A1398 DG
In this case both take the same battery! And here's the guide MacBook Pro(15英寸,带有Retina显示屏,2015年中旬)电池更换
完成的
添加一条评论
添加你的答案
jordanv 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 36
