跳转到主内容
加入维修社区 - 创建账户
微软于 2016 年 11 月发布的一体化台式机。配备 28 英寸 4.5K 分辨率 PixelSense 触摸屏,搭载第六代 Intel Core i5 或 i7 Skylake 处理器。提供 8 GB / 16 GB / 32 GB 内存、1 TB / 2 TB 混合存储,以及 NVIDIA GeForce GTX 965M / GeForce GTX 980M 显卡可选。
Additional Detail on Connector Handling?
First, thanks for the website. Without this i would not have considered cracking open the old Studio. I've replaced both of the SSDs, and will also replace the fans, one of which was locking up, even after blowing 8 years of dust out of it.
I'm having a very hard time with the tiny little fan connectors. Don't want to rip the cables, even though I have new fans to put in.
How exactly does one release the connector? What does one press on, or push, or prod? I've got my trusty spludger here, but have tried pushing on the ends, the sides, and tried jiggling the connectors, but nothing seems to come out. I half-expected to press the "right thing", and hear a satisfying click -- nothing.
Also, the audio connector came out from the board instead of the inline connector, which I also couldn't figure out how to release.
Anyway, enough whining... I hope someone sees this and takes pity. Also, though I don't wish any ill will, I hope the answer helps someone else out.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello @ericleigh007! Let's get this little cable confusion under control!
It appears that the connector you have in the pictures (thank you so much for including those!) is a simple locking connection, meaning the only way to do it is to provide enough force for the clips (see picture) to release.
This guide provides some very helpful tips on how to separate different types of connectors, including the one you are having trouble with; scroll down to step 10 for the connector you mentioned.
Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eric Snyder 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 26
总计 468
