跳转到主内容
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
20 个问题 查看全部
hold down the area above F8F9 otherwise black
I need to hold down the area above F8 and F9 without moving in order to turn on the screen. Otherwise, it remains black.
One day when I woke up my MacBook from sleep mode. I found that the screen was black, but the external monitor displayed normally. Then I discovered that by pressing and holding the area above F8 and F9 without moving, the display would work properly. However, once I released the pressure, the screen would go black again.
I can only use the MacBook with an external monitor, but during usage, sometimes the MacBook's screen would suddenly return to normal. As long as I don't adjust the angle of the screen, I can continue using it. However, if I accidentally move it, there is a high chance that the screen will go black again.
Is this a problem with poor cable connection? How can I fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Try checking the LCD cable connection to see if it has become lose Retina MacBook 2015 Display Assembly Replacement as pressing above the F8F9 keys indicates that is is then making a connection.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
lao3 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 63
