跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
How do I reset a disabled iPod Touch without a computer?
My iPod Touch 4th Gen will not enable. I forgot the password. How do I reset it without a computer?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 316
68条评论
Hold down power and home button until logo shows up and will reset to factory downside is all data will be deleted
完成的
I don't have a computer
完成的
完成的
You can't do it without a computer
完成的
i have ipod 5 touch does it work on this
完成的
显示更多的63条评论
添加一条评论
17个答案
已选择的解决方案
There is no way to do that, unfortunately. You have to put the iPod into DFU mode and then use a computer to restore it. I would suggest trying to find a buddy who will let you use their computer. To DFU the iPod, have it plugged into the computer, hold the lock and home buttons until the device shuts off, wait five seconds, and then release the lock button while still holding the home button. A message should then pop up on the computer telling you that the iPod is in recovery mode and that you have to restore it. Let me know if you have any questions
这个答案有帮助吗?
得分 76
56条评论:
this didn't hepl tell me an alternative method if possible
完成的
@abhisek neymar, just like Jason rightly answered, there is no alternative method. "There is no way to do that unfortunately. You have to put it into DFU mode and then use a computer to restore it." Follow his advise .
完成的
What happens if that does not shut it off
完成的
This happened to mine. I did exactly what he said and it is restoring as I am typing. Thank you so much! This helped and I can't wait even tho it will take an hour or so thanks so much!!(:
完成的
what if a message pops up saying there's an error occurred (3194) ???????????
完成的
显示更多的51条评论
添加一条评论
Requirements :
1. A computer (Mac or Windows)
2. An Apple USB Cable
3. Your iPod
Method:
1. Connect your iPod to a computer running iTunes using the USB cable
2. Make sure your iPod is turned on, the hold both the Home and lock buttons simultaneously and hold for 10 seconds
3.On your computer go to iTunes and click "Restore iPod"
4. Wait for iPod to restore and enjoy!
Hope this helps
这个答案有帮助吗?
得分 14
13条评论:
I get a message that I have to restore the ipod before using it with itunes but when I click ok, the restore ipod screen goes away. How can I keep that screen up to restore it?
完成的
If i restore my ipod touch 4 will it delete my apps, music, pictures, etc
完成的
What if u don't have an apple account how do we do it then it will not let me I try using my aunts account and it will not let me
完成的
but windows doesnt recognize my ipad it keep saying usb not recognize
完成的
What if you have a chrome Book and not able to connect to iTunes i would ask my mom but she would say no so what do i do??
完成的
显示更多的8条评论
添加一条评论
all you have to do is hold the power button and home button at the same time for ten seconds then let go of the power button but keep holding on to the power button for 10 seconds. then it should restart.
这个答案有帮助吗?
得分 8
4条评论:
i tried that before but when i did it still popped up saying iPod is disabled connect to itunes
完成的
it is not working
完成的
Let go of the power button but hold the power button on? That does not make sense
完成的
I know right
完成的
添加一条评论
If you don't have one then you'll need to buy or get a lend of one I'm sure you no someone with a USB cable
这个答案有帮助吗?
得分 6
1条评论:
Would iMac,MacBook include a usb cable
完成的
添加一条评论
I don't have a computer and I forgot my password and the people I do know don't have a computer
这个答案有帮助吗?
得分 5
3条评论:
As I stated before you need a computer to complete this process. Try your local library, apple store or best buy.
完成的
wow "the people i DO know" makes it sound like you live in a cave and the only people you DO know are the ones who you haven't eaten yet.
完成的
verizon stores will unlock or reset your ipod for free! u dont need a verizon account!
完成的
添加一条评论
yes unfortunately you cant do anything without the computer i tried everything and still does not work. my charge bars are bent so it does not work i will try suggestions if any one has some very appreciative
这个答案有帮助吗?
得分 4
1条评论:
verizon stores will unlock or reset your ipod 4 u for free, u dont have to even have a verizon account
完成的
添加一条评论
Well basiclly you press the sleep wake button and home button for 10 secs till Apple icon appears. Then let go of the buttons. Hope this helps!
这个答案有帮助吗?
得分 3
3条评论:
that didnt help at all i tried a couple of times but it didnt work ):
完成的
i found an ipod touch 2nd generation its has a password and i need help unlocking it.how do i do that without a computer
完成的
Close, you need to continue to hold the home button after 10 seconds and releasing the lock button. That is the difference between a forced reset and putting it into DFU mode. Alisha first off you should contact Apple and try to return the iPod. I am sure someone is missing it
完成的
添加一条评论
i found a ipod touch, but ican't to delete the id and password.
这个答案有帮助吗?
得分 3
1条评论:
Take it to Verizon they will unloOk or reset it 4 free, NO verizon account needed, takes 10 min
完成的
添加一条评论
Can I plug into another phone using iTunes app then do the reset function? ?? Would that work
这个答案有帮助吗?
得分 2
添加一条评论
Can someone help me unlock my iPod touch 5 i got it on letgo serial number is dj6kt0cff4k4 can someone help me out
这个答案有帮助吗?
得分 2
添加一条评论
IPod 5 no enciende que se le hace
这个答案有帮助吗?
得分 2
添加一条评论
well you get your usb cable and hook it up to an outlet than you take a pic then you will go tot he lockscreen and slide up so on the left hand side you will see a flash light Image than right next to it on the right there is like a watch images than you will click on that then you press the sleep/awake button then it will say slide to sut off under that it will say cancel you pres on cancel then you wil press the home button 2 times really face hope this work cause it worked on mined
这个答案有帮助吗?
得分 1
3条评论:
What?Wheres the correct spelling?
完成的
i've erased my ipod, version: 421(8c148) model:MB52LL
完成的
Apple iPod 7.0.4. Serial number-ccqm345gffcj. Says connect to itunes
完成的
添加一条评论
If you don't have a computer then go to the Apple store, and use one if those. They will let you use it.
这个答案有帮助吗?
得分 1
添加一条评论
how do i reset a ipod if it wont go into dfu mod it just shows the apple logo
这个答案有帮助吗?
得分 1
添加一条评论
Get my ipod said disabled CONNECT itunes how get off please help me
这个答案有帮助吗?
得分 1
添加一条评论
I know how you feel, my dad will recover it, but try to find a nearest Apple store, or use your teachers MacBook or iMac! Hope it helps! I’m in 5th grade so this should help! :)
这个答案有帮助吗?
得分 1
1条评论:
Apple store will let you borrow computer
完成的
添加一条评论
How do I unlock my ipod without a computer
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
kato 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 58
过去 30 天: 288
总计 486,313
