跳转到主内容
The Dell Inspiron 580 covers the basic computing needs. It may not provide the most advanced version of each feature, but the basics are available and provided for users.
12 个问题 查看全部
F1 and F2 black screen on boot up
When I start my Dell Inspiron 580 with Windows 10, Black screen with F1 to continue to desktop and F2 to view system bios key choices is shown. How do I fix this. Other suggested fixes are not in my system bios options.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Probably, the cmos battery (button battery, CR2032), is low, and/or the system time is not set.
Once the time is set, the screen should not repeat on the next startup.
If it does, the battery is likely dead, and must be replaced to hold the time.
The battery is on the mainboard, and should be visible.
这个答案有帮助吗?
得分 2
1条评论:
The CMOS battery fixed the beeping, which happened after my post, but the black F1 F2 screen still shows up when starting up. Also, I have a power center that switches off the power to my Dell after shut down. When I switch the power on, the Dell starts up. Before, I had to press the power button on the Dell after the power center switch was turned on.
完成的
添加一条评论
You haven't given us much information. Do you get the Dell logo screen?
You have already mentioned the <F1> and <F2> keys.
When it starts up press <F12> key to get to Boot Options and select your hard drive.
If no drives appear then your hard drive may be defective. Did it show up when you went into the BIOS?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
senseimiller 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 51
