跳转到主内容
加入维修社区 - 创建账户
My Dx7590 dropped on the ground and does not AF focus anymore.
I dropped my Dx7590 on the ground and AF focus does not work anymore. Whenever I pressed the focus key half way, the AF light is red and all image is blurred. Is it possible to fix it by myself and how? Thank you so much.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Try pulling the battery for the camera and let it sit for 5-10 minutes. Put the battery back in the camera and see if that resolves your issue. If not, most likely the lens is slightly out of position.
这个答案有帮助吗?
得分 0
2条评论:
I followed your instruction but the AF is still blurred. What is the next step? Than k you.
完成的
I don’t have any other steps that you could take, someone else is going to have to help you, sorry. The only conclusion I can come to is that the lens is slightly out of position after the drop.
完成的
添加一条评论
添加你的答案
Atant 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 8
总计 191
