跳转到主内容
发布于2019年9月20日,这是苹果在2019年发布的最大且最贵的智能手机。它带有6.5英寸的OLED显示屏、三摄镜头以及大幅提升的电池续航。它继承了iPhone XS Max产品线。
165 个问题 查看全部
Battery disconnects after dropping by mistake.
I got my battery replaced from an third party vendor for apple and the cowlings are missing after the same, because of which the battery shuts down instantly and is not turned on unless I get the battery in place with help of a insulated tape. Is there a permanent solution for this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
When placing battery connector back onto the board does it pop off right away or does it stay clipped in? (If it pops out right away then the connector maybe damaged. If it stays in then I would look into possibly purchasing brackets online or seeing if repair shop would resolve issue.
这个答案有帮助吗?
得分 1
添加一条评论
I agree with Edward, that sounds like it could be a connector issue. First off, you can buy specifically-made adhesive strips for your battery here, and replacement display adhesive here. And if that doesn't work, I recommend that you try replacing the battery yourself. You can get a replacement here.
iPhone 11 Pro Max Battery图片
产品
$34.99
iPhone 11 Pro Max Battery Adhesive Strips图片
产品
$3.99
iPhone 11 Pro Max Display Assembly Adhesive图片
产品
这个答案有帮助吗?
得分 1
添加一条评论
If you look around online you can find a replacement for that little bracket that holds the battery connector on. Here's one example I found after a quick search; you can probably find more if you look a little harder.
Apple iPhone 11 Pro - Metal Cover Battery Connectors
You can frequently find it being sold in a bundle as "small parts" on places like eBay and AliExpress as well.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Vigneshwar H 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 39
