跳转到主内容
Steam Deck 是 Valve 公司于 2022 年 2 月 25 日发布的游戏掌机。本页面包括 Steam Deck 搭载 LCD 屏幕机型的维修指南、拆解信息,以及疑难解答。机型代号1010。
SSD upgrade storage issue/question
I recently cloned the stock 64gb ssd onto a 2tb ssd. I replaced the stock ssd and the device works fine, but it's only showing 476gb of storage. I'm wondering if this is an issue with the ssd itself, or it's partitioned or something along those lines where the correct storage space exists and is just not showing as available.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Hey there @oofmadone,
I tagged @flannelist for input on this question. They have some really good insights for Steam Deck issues and even wrote our troubleshooting pages for this device. I'm willing to bet that it is a partitioning issue with the SSD since you should be able to upgrade your SSD to 2TB without issue. I would also maybe check out the Steam Deck SSD Replacement Guide and see if a step was missed during the upgrade process.
这个答案有帮助吗?
得分 1
3条评论:
Hi friend, thanks for your input! My first thought was that it was a partition issue also. I did not format or otherwise check on the ssd before cloning the stock drive, I think I'll try to go through the process again and see if I get the same results. I'm thinking it's possible the replacement ssd needed to be formatted some way or came partitioned and then just installed the data onto one of those partitions.
完成的
@oofmadone I mean if push comes to shove, you could always reformat the 2 TB drive and image the Steam Deck OS to it. Then Just transfer the files from the old drive to the new one.
完成的
@oofmadone I think you're onto something here for sure. How did you do the format the first time around? Depending on where you got your drive, I would also give this spiel about verifying the authenticity of an SSD a glance. It's an unfortunately rampant problem.
完成的
添加一条评论
添加你的答案
Oofmadone 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 728
