跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1202 个问题 查看全部
iPhone X stuck in boot loop, logic board tested in another iPhone
Hello,
I'm encountering an issue with my iPhone X. Earlier today, while I was watching a YouTube video, my phone spontaneously restarted. It then indicated that Wi-Fi was unavailable, and the cellular network remained stuck on "searching." Subsequently, it shut down and restarted itself multiple times, repeating the same behavior.
After a couple of reboot, it couldn't pass the Apple logo.
I've attempted several troubleshooting steps and even conducted advanced tests. Here are the key observations:
  1. The logic board is stuck in that boot loop, even when only the display and battery are connected.
  2. The boot loop consists of alternating 10-second intervals of a black screen and the appearance of Apple's logo.
  3. When I transplanted my motherboard into another functioning iPhone X, it exhibited the same problematic behavior.
  4. Conversely, when I placed the motherboard from the working iPhone X into my iPhone X, it booted normally.
  5. When I attempt to enter recovery mode and restore it, the phone restarts, shows the Apple logo, and then returns to the recovery screen. Finder.app gives this error: The iPhone “iPhone” could not be restored. An unknown error occurred (4013).
  6. DFU mode is detected by Finder, but restoration fails on "Waiting for iPhone" as the iPhone gets into a boot loop
➡️ Can you please advise on how to resolve this issue?
➡️ Do you know if there is a way via the bootloader exploit to boot in verbose mode?
Thanks
UPDATE 21/10/2023:
I've played a bit with a SSH Ramdisk. The iPhone starts booting (showing text lines because of verbose mode), and then lines disappear and the phone restarts.
UPDATE 22/10/2023:
I managed to take a photo of the SSH Ramdisk output:
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I'm afraid you're well into expert level board repair here and there are just not a lot of experts in that specific area. That being said, take a run over to repair.wiki, which has an extensive information page on iPhone X debugging. Run some of the diode mode tests and debug procedures which may help point you in the right direction.
iPhone X - Repair Wiki
Good luck; let us know what you find.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Romain Giovanetti 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 125
