跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1202 个问题 查看全部
Why is the phone in a boot loop after screen replacement?
Hi all - I've changed the screen on a friends iPhone x and it is now stuck in a boot loop. I have changed iPhone X screens probably. 20 + times and never had this issue and I don't think that I damaged anything this time round either.
Initially it would only boot loop whilst on charge and would do nothing at all when not plugged in so I thought perhaps it had to do with power delivery so I changed the battery too. Now it still boot loops, but both whilst plugged in and not plugged in.
I've tried hard resetting it on the phone itself and it didn't do anything. My PC. also won't recognise it when I plug it in via USB so I can't do anything in iTunes. Any ideas? Please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
You may be able to find some awnsers in this article. https://discussions.apple.com/docs/DOC-2.... Other than that, I don't know much about the iPhone X, so I won't be able to help much on this. You may also want to remove the battery cable and then plug it back in after a few seconds as to reset RAM and stuff like that. Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris Gibson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 52
