跳转到主内容
于2019年9月发布的中端手机。在中国和印度的别名为Redmi K20 Pro。 具有6.39英寸Super AMOLED显示屏,Snapdragon 855处理器,、27W快速充电功能、4000 mAh电池、屏下指纹、弹出式摄像头以及48 MP主摄加上13MP超广角镜头和8MP长焦镜头。
23 个问题 查看全部
My phone fell in water and from that time display stopped working
Actually I was moving on bike to my friends home I was in some sort of speed I didn’t see the pit on the road and my phone fell in water from my pocket and first half an hour the screen worked after half an hour some sort of Glenn lines appeared on the screen after some time totally phone display has gone but I am receiving calls and notifications and alarm but the display is off I am unable to use my phone so please help me I found this website is very useful and getting immediate response so I came here while searching out online for my phone so I hope the best THANK YOU
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @nivasreddych
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is the ifixit Mi 9T Pro guide that may help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nivas reddy ch 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 38
