跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
Why does my Airport take so long to connect?
Sometimes, when I open my MacBook, it takes a few minutes to find any wireless networks. On other MacBooks, it takes a few seconds. Sometimes, my MacBook finds a network right away, but sometimes, it takes forever. How can I fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
This may or may not be a factor but go to system preference, network, then click on advanced. in the first tab, under airport, check out how many preferred networks you have listed, get rid of any that aren't networks you use regularly and finally if you're left with more than one network drag your home network to the top of the list.
hope that helps
这个答案有帮助吗?
得分 3
2条评论:
I've done this before, and it worked a little. I'm trying it again, and I'll see how it goes after a few days.
完成的
It totally worked!
完成的
添加一条评论
Mine has the same issue, started happening after i upgraded to snow leopard. I haven't found the culprit of this yet... although when i changed the network configuration away from a 128WEP to a wpa it started connecting right away 95% of the time as opposed to 60% before...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sterling Hirsh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 2,541
