跳转到主内容
加入维修社区 - 创建账户
Dell Precision 5550 工作站是 Dell 生产的一款笔记本电脑。本页面包含与 Dell Precision 5550 相关的维修和服务信息。
Battery Replacement Not Accepted
Hello. I just received a replacement battery from iFixit, and my laptop won’t boot into windows with it installed. Placed the old battery back in, and everything works just fine.
Does Dell lock their BIOS down if non-Dell parts are installed? And is there a trick to bypassing this?
Battery is the Dell 69KF2
Edit: The picture is the error I receive when plugged in
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
With the new battery installed, does it make it to the BIOS or does it completely brick up?
由完成的 分享
It makes it to the BIOS, but it warns me that the battery isn’t a Dell certified battery.
由完成的 分享
So it comes up and has a warning that your battery isn't genuine and it won't let you past it?
由完成的 分享
Yes. That’s exactly it.
由完成的 分享
Yep, I believe dell has some chip that does a virtual handshake with the battery to make sure it's oem.
Edit: Sorry i can't be of much be of much help, dell is kinda funny like that and I actually just went through this same thing but I ordered from parts people to make sure it was oem.
由完成的 分享
添加一条评论
2个答案
最有帮助的答案
The issue here is Dell uses a custom TI battery gauge which also does a challenge/response code with the BIOS; if the response is not emulated (legal issues for sites like iFixit to knowingly sell) or a Dell BMS is reset and reused (legal since it's not cloned), it will reject the pack. This started with the E series due to the D series 2005 Sony recall. The issue is now by the time it's cracked, the laptops are so decrepit it doesn't matter to Dell, and the machines are mostly retired. Maybe RtR will fix this on future machines (potentially some older models), but Dell has begun to sell batteries on their site for "internal" laptops :-). This is where you can get the "right" battery now. You can get it at a slight discount from PartsPeople as well.
While Dell doesn't vendor lock things like SSDs and RAM (even screens), the battery IS locked down. That's why you can get a garbage spec machine from them with a good CPU at a healthy discount as a factory refurb and then buy the parts you really wanted like a 1TB SSD.
这个答案有帮助吗?
得分 2
添加一条评论
Dell doesen't usually do this, so it can be a problem with the battery. Try cleaning the battery.
这个答案有帮助吗?
得分 0
2条评论:
Yeah, I think Dell is usually pretty open about repair and parts.
由完成的 分享
I thought so too, but the photo from the BIOS is the error I receive when I turn the machine on
由完成的 分享
添加一条评论
添加你的答案
Logan Endicott 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 98
总计 2,076
