跳转到主内容
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
293 个问题 查看全部
Intermittent Booting: Stuck at Apple Logo with No Progress Bars
Greetings, iFixIt,
I find myself quite worked up with a boot scenario of an 2017 iMac 4K model (iMac18,2 i5) from a customer, which appears to be similar if not exactly the same as described in this post.
Some of my observations:
1. Power Drain Ritual:
  • This iMac exhibits a higher success rate of booting up post a "power drain ritual", which I'd have to disconnect the power cable, let it drain, then rebooting. However, this isn't consistent.
2. Verbose Mode Halt:
  • On occasions where I verbose booted with a hotkey, the iMac gets halted at EB|LOG:EXITBS:START. A hard reset followed by a verbose (halt) reboot has, at times, allowed the system to boot successfully.
3. Fan Behavior:
  • Upon plugging in the power cable while holding down the power button, the fan spins at full speed, maintaining the same speed even post boot. While the fan is spinning at full during user selection, within seconds, the OS crashes and pops the message "your computer restarted because of a problem", and this loops endlessly when the fan is at full spin.
4. Thunderbolt/USB-C Port Malfunction:
  • The Thunderbolt/USB-C ports does NOT work, when booted and opening system information, "Thunderbolt/USB4" returns "No hardware was found".
5. SSD Health Check:
  • I took off the SSD, analyzed via CrystalDiskInfo on my PC, it portrays a "healthy" status at 1% health. The main key metrics include a total host read of 97266 GB, total host write of 80078 GB, and a power-on count of 211035 instances over 2519 power-on hours.
    I suppose the high power-on count to be originating from a theory that the previous owner left the iMac powered on for weeks while it was stuck at the Apple logo, potentially racking up the SSD’s power-on count; I imagine the iMac could be incessantly running POST tests while it's stuck at the Apple logo.
6. No Grounding Pin:
  • The grounding pin on the power cable is missing, I suppose its ripped off by the customer, perhaps a power surge without ground caused these hardware failures? Though I suspect the power supply itself must've been able to mitigate it in the first place.
7. Standard Troubleshooting:
  • I've done NVRAM and SMC resets, reseating internal connections, and updated macOS to the latest version at Ventura 13.6, alas, to no avail.
With verbose halts, fan orchestras, and Thunderbolt ghosting. I'm reaching out to this community to shed light on this.
If you have any information, if at all, please let me know how this could be potentially solved. Thank you all.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Well… this is a bit of a mess!
I would se an external boot drive with Mojave or higher to see if you can boot under it.
Download the macOS from here How to download and install macOS on another Mac system, then format a USB thumb drive with the Mac to GUID and copy the installer file to it. Then follow this guide Create a bootable installer for macOS
Using it see if it will boot up, you may need to use the startup command Option (⌥)
Referencing this guide: Mac startup key combinations
Did that make a difference?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
SGpro 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 8
总计 38
