跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2266 个问题 查看全部
Can I swap battery cells 6S to 7?
Long story short I have a 7 that has a battery so dead that the phone won't even detect it anymore. Is it possible that I can take the good cell off of a 6S battery and connect it to the iPhone 7's BMS to make a 'new battery'. It would only be temporary but I don't know if it's possible.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Actually, I'm going to disagree with @corbanizer and suggest that there's no real reason it wouldn't work. The base chemistry of the battery cells is the same; they both take the same charging voltage at roughly the same rate and the BMS will regulate that. I'm guessing he 6S battery is slightly smaller so it will have a marginally shorter run time, but I doubt it's enough to make a significant difference.
As Corban said, the best strategy would be to simply buy a new 7 battery, but honestly there's no reason your plan won't work. The only catch here could be physical limitations; the electrodes coming out of the 6S cell have to be similar enough in geometry that they can be connected to the 7's BMS, and the physical size has to be such that it will fit into the 7's battery compartment and let the connector plug in.
If you do go ahead with this, be sure and come back and show us pictures of either the process or the finished product and let us know how it worked. Success stories are always appreciated, and we can usually learn something even when things don't go as planned.
Oh, one last thing; the best method for working on batteries is using a spot welder, as it minimizes the heat the battery cell is exposed to. If you don't happen to have one of those little devices, then solder carefully and use as little heat as possible; just get them tacked on so there's a good electrical connection.
这个答案有帮助吗?
得分 3
3条评论:
Currently working on trying this out, so far the hardest part is trying not to be scared of the batteries and getting the BMS out of the adhesive shell they're in. Will keep you posted and thanks for your detailed answer :)
完成的
Update: damaged the BMS flex so couldn't continue, ordered a new battery with next day shipping
完成的
@keiranmelton Aw rats, I was looking forward to the experiment. Well, at least that'll get you going.
完成的
添加一条评论
I wouldn't try it. Apple is known to not like that kind of thing and they have compatibility issues. I would just buy a new Iphone 7 battery and do it right the first time. Buy Once, cry once.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Keiran Melton 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 7
总计 60
