跳转到主内容
Apple's seventh-generation smartwatch, with optional cellular connectivity, released October 15, 2021.
13 个问题 查看全部
Will a 42mm battery fit in a 38mm Apple Watch?
I have a 38mm series 7 Apple Watch and recently the battery went bad and I need to get a replacement. I was looking for a replacement battery for the 38mm Watch but I can only find them for the 42mm and 45mm. so are the 42mm battery’s interchangeable with the 38mm watches?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Simple answer no!
You can’t physically fit the larger battery into your watch.
这个答案有帮助吗?
得分 0
3条评论:
Just to expand on Dan's absolutely correct answer, devices like cell phones and watches custom design their batteries to fill all available space to give you the maximum battery life. So naturally since the 42mm watch is bigger than the 38mm watch, that means there's more space inside to hold a battery. Which means the battery is going to be bigger and, as Dan pointed out, you can't fit the larger size battery into the smaller space.
完成的
If I can’t fit the 42 mm battery in the Watch do you guys have any idea where I might be able to get a 38mm one?
完成的
@eliduffer - Here’s the guide and it offers the needed parts to replace the battery Apple Watch Series 7 电池替换
完成的
添加一条评论
添加你的答案
Eli Duffer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 15
总计 104
