@alexlinnecxr not sure what a "dipped headlight" can you explain this? Is this a new issue with your Corsa? Anything that happened to it? You made sure you do not have daytime running lights on the Corsa. what have you checked?
@oldturkey03 my car does not have day time running lights they simply just won’t turn off the dial doesn’t work to switch them off once the ignition is on completely confused, as I’m quite good with cars but not wiring at all
由 oldturkey03 完成的
由 AlexLinnecxr 完成的
