跳转到主内容
The DSLR D3100 from Nikon was released in August 19th, 2010. Features a 14.2 MP camera, Full 1080p HD movie, and a 3 inch LCD screen.
30 个问题 查看全部
Why can't I close the pop up flash?
my pop up flash would not close, even though their are no broken elements what so ever within the camera or the flash system
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Do you mean it's open and it won't move so you cannot close it, or that when you close it, it pops back open again?
完成的
yep the latter, it pops back and opens again
完成的
添加一条评论
1个答案
@hanyalbaghdady if your flash does not stay closed, it is possible that this is caused by a bad latch. Turn your camera around and look at the flash housing. Next to the hole that catches the hook in the body should be a very small Allen screw. Gently try to turn it to adjust the latch. If that does not work or if there are other issues. Check the Assemble/Disassemble part of the SM Nikon D3100 for your camera. Let us know what you find.
If you need to change the hook, check something like this video (not your exact model but close enough to get an idea)
这个答案有帮助吗?
得分 0
2条评论:
Thank you for the detailed answer, but im looking for the alen key screw in the flash housing and it only has two small Phillips screws within this area. I wish their was a way to attach a photo it would explain alot.
完成的
@hanyalbaghdady you can add pictures. Just edit your Question and use this guide 在已经存在的问题里加入图片
完成的
添加一条评论
添加你的答案
Hany AlBaghdady 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 39
总计 98
