跳转到主内容
Model A2159, EMC 3301. A refresh of the entry-level 13" MacBook Pro. Available in Silver and Space Gray. Released July 2019.
113 个问题 查看全部
Replaced screen only to break "ZIF data power connector"
I was given an 2019 A2159 MacBook Pro with an broken screen, I was able to use the laptop after I removed the screen pluged-in via USBC-HDMI, and also it ran on battery without its screen. Once I replaced the screen, the battery no longer works, the culprit being I broke the ZIF connector lid for the battery data cable
https://imgur.com/a/JI4AsTh
The thing is, I'm sure I broke that piece off on my first go.. only for it to not work upon the screen install. I don't have any electronics expertise to diagnose this further.
  1. Can I source a replacement ZIF or ZIF clamp? I'll have a professional solder it on if need be.
  2. Any chance something else could have gone wrong, and its just a coincidence?
Update (09/11/23)
https://imgur.com/a/yIEPMKl
Closer up photo
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@thomasmulford - The latch is replaceable if that’s what went on a one way trip in the process of unlatching it. I can’t tell if that’s the issue based on the image.
这个答案有帮助吗?
得分 1
3条评论:
Please add some better photos of what you think you broke.
完成的
@thomasmulford - Not good 😫 while it’s a bit clearer I think the main shell is damaged so replacing the latch won’t help you here.
This will require someone with good micro soldering skills and a small nozzled hot air station to replace the connector.
完成的
Thanks Dan! I'll look around for business who can solder it!
完成的
添加一条评论
添加你的答案
Thomas Mulford 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 49
