My car sunny 2005 engine check light on
I have check light problem, i was check all my spark plugs and coils and i also checked computer there is cods P0350
P0304 but still check light on please help me for solving problem
The P0304 code means that cylinder #4 is misfiring or is randomly misfiring. The P0350 code means that the Powertrain Control Model (PCM) has detected a problem with the primary or secondary circuit of one or multiple ignition coils or ignition coil packs in your engine.
The P0304 code is a serious engine issue that requires immediate attention. A misfire is the absence of a full combustion event on a given cylinder as expected.
Here are some possible causes of a P0304 code:
Here are some possible causes of a P0350 code:
The most common symptom of a misfiring engine is a loss of power. The engine may also run rough, be difficult to start, or stall completely.
Here are some repairs that can fix a P0304 code:
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 83
总计 534
@waqasbajwa67 how did you check your spark plugs and your coil? Hopefully you changed your plugs….:-)
由 oldturkey03 完成的
A P0350 indicates that the Powertrain Control Module (PCM) has detected a malfunction in the circuit of one or more of the engine's ignition coils.
由 F Dryer 完成的
I'm not familiar with this car, but if it has individual coils for each cylinder then I'd start with replacing the coil on cylinder #4, since the other code, P0304, indicates a misfire on cylinder 4. At the very least you could try swapping #4 coil with another cylinder and see if the misfire follows it.
由 Jerry Wheeler 完成的
I have check engine light problem car racing during the drive suddenly showing check engine light and accelerator not working speed reduce 10-20 KM what's the problem
由 Awlad Hossain 完成的
@awladhossain You will need to get the car scanned for whatever trouble codes are causing the check engine light to turn on. Here in the US most auto parts stores will scan your car for free, but if that's not a service provided where you live you can buy an inexpensive bluetooth OBD-II device that can be read with a free app on your phone.
Best if you start your own question and add the trouble code information when you get it.
由 Jerry Wheeler 完成的
