Pressed button won’t stay
Wii remote “B” button won’t stay pressed, the b button works just fine but if I try to do a hold press it will only do a quick press
This problem happens with all the Wii remotes I’ve tried and I’ve replaced the batteries and powered the console on and off to no avail, the buttons are clean and are not sticking
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Not an expert but the problem might be inside the remote. I assume there’s a trigger for the button and that it’s pressed in too far.
完成的
Just to add: Can you share some pictures with us? Then we can check where it goes wrong. Thanks!
完成的
添加一条评论
