跳转到主内容
Apple 專為可望極致效能專業使用者所打造的產品線。目前, MacBook Pro 產品線包括 13、14、15、16、17 英寸機型,並且大致分為原始非一體成型機身、一體成型機身、視網膜螢幕、觸控列、Apple晶片五個世代。
20 个问题 查看全部
问题已关闭
Torx T6 stripped/stuck screw removal.
I need to replace the iSight camera in a MacBook Pro. After reviewing your video on removing the LCD screen, I realized it was the same process.
However, the video show the two main segments of the unibody separated.
That would mean the hinges needed to be removed from the base.
3 Torx T6 screws hold each hinge in place. One side came off nicely with a T6 screwdriver, the other not so great.
I've tried using heat with a soldering iron. That helped with one screw. That leaves 2.
Then I tried an extraction tool (ezout). That just chips out the screw with no movement.
There is still some head left.
What other options do I have?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
It may be now that the fixing which the screw goes into (usually seen as a copper colored barrel shape), is broken away from the laptop casing itself :( So no matter what you do, the whole screw and barrel will just be spinning around.
The only thing i can suggest now is to use a 0.5mm drill (hard to find, and you've gotta be soooo gentle with them), and tap a small hole into the remains of the screw shaft - then use a smaller sharp ended screw to grip the old one, and hope it can move it.
If the screw and barrel really are turning, then the screw is probably so tight in the barrel that you can only drill the whole thing out till it gives up and falls out.
One other method I've used a few times successfully is to use a cutting disc on a small drill (a very thin one), and make a slice in the top of the screw head - then a flat blade screwdriver can turn it as normal.
Screws are a wonderful thing, until they just wont unscrew :(
这个答案有帮助吗?
得分 0
添加一条评论
To avoid stripping/damaging the TORX screws use a RATCHETED battery drill (NOT hammer type for drilling tiles/concrete). MOST battery drills are equipped with a ratcheted chuck, even my very old super-cheap Tandy (yep Tandy) supplied battery drill. Set the ratchet setting to its lowest setting for your first attempt and increase to higher settings if required.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 11,046
