跳转到主内容
加入维修社区 - 创建账户
PS5 游戏机于 2020 年 11 月发布,其视觉效果大幅升级,并配备了创新的全新 Dualsense 控制器。太空时代的黑白配色方案与过去的 PlayStation 设计大相径庭。
What is the real answer
I don't have a plalystation 5 console yet, interested in getting one, but I do have a question that seems to have conflicting answers.
Is the playstation 5 disc drive paired to the motherboard?
Some say yes and some say no. Who knows for sure?
I ask this because I don't have a problem swapping out a motherboard and a disc drive, but I find it hard to believe that Sony would go down this path. With playstation 3 and 4, you left the daughter board in and took out the disc drive if it broke which I have done on both systems.
So with every disc version playstation 5 sold to consumers, we all will have to get motherboards and disc drives which will cost almost as much as a playstation 5 console if the disc drive breaks?
There is no daughter board with the playstation 5. Or can you switch disk drives and everything still works?
So if you have a playstation 5 console with a disc drive, does it make more sense to just get another console of the same type and do a data transfer or do you spend the money and get a paired playstation 5 console and disc drive.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I don't have a ps5 and don't want one due to the liquid metal leaking from the CPU issue. But, after having a Google it looks like the drive is replaceable.
这个答案有帮助吗?
得分 1
添加一条评论
There is a daughterboard and it is paired to the motherboard, at least for the launch variant.
You can take the daughterboard off and only replace the mechanical part of the disc drive, that will be much cheaper.
这个答案有帮助吗?
得分 1
4条评论:
Does it depend on which disk drive model you have? I think Sony did like 4 versions. The latest one doesn't have as much copper for the heatsink as the launch model did.
完成的
@gamekid Somebody needs to track Sony’s production changes to be able to answer that.
完成的
After doing a lot of research on google, either this is just on the launch models or Sony and Microsoft for that matter, are trying to prevent piracy from happening.
I don't like the idea of that, but if that is the price we all pay for having a playstation 5 or xbox series x, that's what it is.
完成的
@gamekid No need to worry, you can always take the daughterboard off the drive, why would you replace the whole drive anyway?
完成的
添加一条评论
添加你的答案
Justin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 540
