跳转到主内容
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316 个问题 查看全部
DS Lite wont turn on. But having a GBA cartridge boots into GBA.
I'm not sure why but my DS Lite would shut off as soon I turned the console on with a white screen for 0.5(?) second. But for whatever reason, if I insert a GBA Cartridge into the system. It boots into the GBA cartridge. But wont work if there a GBA And a DS cartridge inserted at the same time. Is there some sort of fix?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Look's like your top screen ribbon cable has an issue, i had the same problem with three DS's , your lucky that your GBA cartridge is working because you left it on manual mode, you need too replace the top screen, unluckily there's no other solution
DS Lite Upper LCD Replacement
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bashy Bush 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 19
