跳转到主内容
Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
20 个问题 查看全部
Help Finding DSi XL Lower Screen Backlight Fuse
I was making a DSi XL Macro mod. It worked for a little bit, but it just randomly quit. It blinks blue for a second, and dies. The bottom screen didn't blink like I'd expect if the 330Ω resister failed. Ive tried known good lower screens on this, Which leads me to believe its the lower backlight fuse, However, I cant find where the fuse is. Does anyone know where it is?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
The DSi has 2 fuses, both labelled F1 for some reason. The first one is near the charging port
and the second is on the underside of the power board.
I think the one you're looking for would be the one on the power board, but I'll let you determine that for sure. Good luck!
这个答案有帮助吗?
得分 1
2条评论:
Unfortunately, those fuses are unrelated. Those fuses are power related (charge fuse and battery fuse respectively) I need to find the fuse or component related to the lower screen backlight.
完成的
@soup244 Well, those two are the only fuses in the console, so something else must have failed. Unfortunately, I don't know what it might be
完成的
添加一条评论
添加你的答案
Soup 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 95
