跳转到主内容
Released on July 28th, 2017, the New Nintendo 2DS XL is a handheld gaming console succeeding the Nintendo 2DS.
203 个问题 查看全部
Right speaker connector torn off the motherboard
Hi, I recently had to open my New 2DS XL to replace my Dpad, as the previous one had a serious drifting issue. The problem is that I accidentally torn the right speaker connector off of the motherboard and I thought just putting it back in place would work, but that wasn't the case. Now the right speaker isn't working and I was wondering if it's because I have to solder it back in place. I have attached a picture that I got from the repair wiki where I've circled the connector I'm talking about for clarity.
Thanks in advanced.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
It does appear you have to re-solder the connector on, and potentially you may have to buy a new connector.
这个答案有帮助吗?
得分 0
添加一条评论
G'day,
If you've torn the speaker connector off, chances are you've also torn the pads with it. My advice would be to see what you can use with the old connector, but you'll need to run some wires in order to have it function. Also, you'll need to run some wires from the traces on the board to the connector by scraping some of the coating off to expose the copper.
hope this helps :)
-NP
这个答案有帮助吗?
得分 0
1条评论:
So what you're saying is that not only would I have to solder the connector back to the motherboard after scraping it, but also solder in additional wire inside the connector to restore the electrical current from the connector to the speaker cable?
I didn't understand very well.
Also yeah, I ripped off the pins alongside the pads you were talking about unfortunately.
完成的
添加一条评论
添加你的答案
RokuMH 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 19
总计 95
