跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
Why does my keyboard from ifixit not fit?
I ordered a 2012-2015 MacBook Pro 15” keyboard from ifixit but it doesn’t fit my 2015 MacBook Pro 15”. There’s a notch below the spacebar on MacBook’s the upper case that doesn’t match up with the notch below the spacebar on the keyboard.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Good morning,
Last i checked, it isn't technically possible to replace the "keyboard" (the actual key mechanism) on it's own without pulling a Hugh Jeffreys. If your replacing the top case however, then that should work.
Can you add a photo showing the clearance issue as, from looking up on the internet, i can't find any obtrusive notch on the keyboard
这个答案有帮助吗?
得分 0
1条评论:
My bad, I’ve realized that the keyboard does fit. I’ve uploaded a photo as an answer. I thought the bit that juts out (circled in blue) goes around the the bit that’s circled in red.
完成的
添加一条评论
添加你的答案
Owen Smith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 96
