跳转到主内容
The VLT 1000 desktop fan has four blades with a diameter of 30 cm. It is made of stainless steel and has 3 speed settings.
9 个问题 查看全部
Electric wire burn want to replace with new wire.
Want to replace new wire so help me with main neutral and earth connection
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
@ivaanmaran67435 post some pictures of where the wires are connected now. That way we can see what you see and hopefully help you with that. 在已经存在的问题里加入图片
完成的
I agree Ivaanmaran above. Question. Did the wire burn occur on its own or was the cord next to an hot object?
完成的
添加一条评论
1个答案
Dear Ivaan Marandi and Eva Marandi,
If your cable is not compatible with the voltage you need, please try replacing it with a cable that matches the required voltage. Additionally, consider changing the fuses in the cable socket and try again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
IVAAN MARANDI AND EVA MARANDI 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 71
