跳转到主内容
加入维修社区 - 创建账户
模具型号A1707。于2017年6月上市,这台MacBook Pro的特征为配有Kaby Lake处理器,可升级至2.9GHz、可动态超频至3.9GHz四核英特尔酷睿i7处理器。
My MacBook Pro's usb c ports are killing my devices
Hello everyone.
I got a friend's MacBook Pro (15 inches, 2017) today, the MacOSX was damaged so I formatted and install high sierra on it, I mounted an iso image on a USB and connect it to a USB C hub, and all the progress went just fine.
After finishing the setting up, I expulsed the hub, the next time I connected the USB c hub with a USB the Mac alert me with a message that "USB Accessories Disabled" and my hub led went off, I tried to reconnect it another laptop and computers but it doesn't work again.
I asked the owner about it, he told me that got 2 external hard drives damaged after using them in the Macbook.
Does everyone have this problem before?
I searched on the internet about it but I can't find anything about it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
The first thing I would do is have a good look at the ports themselves. You will want to take them out to inspect. Use the Battery Replacement Guide up to step 49 to get your logic board out. The USB C boards are held in with 2 T5 screws and should pull right out once you get the board out. Beyond that, this could be a board level issue. I would give that a good look as well. Check for anything that looks out of place, damaged, burnt, etc...
Feel free to attach pictures to your original post and we can take a look!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Luis Medina 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 193
