跳转到主内容
加入维修社区 - 创建账户
Support for percolators manufactured by Farberware.
12 cup percolator with plastic handle broke Why?
the handle broke at the top. Why?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If the coffee maker you're referring to is the one pictured in the device page you selected, then it's made of a material called bakelite. Bakelite is pretty durable, but is susceptible to age and eventually will break down at stress points like what occurs every time you pick up the percolator.
So age is your most likely cause, but of course it can also simply be broken by being dropped or banged against something else. If you post some pictures of what you found perhaps we can help figure out what to do next. It may be possible to use some very strong glue like epoxy to put the handle back together, but we won't know until we can see what you're up against.
Adding images to an existing question - iFixit Repair Guide
这个答案有帮助吗?
得分 0
3条评论:
the coffee maker is the 12 cup percolator. It wouldn't let me change to the one I have.
完成的
my 12 cup percolator has the one handle connected from the top to the bottom and the top one broke off. Did not drop or bang it.
完成的
@mariesacca26145 Can you add pictures? That would help.
完成的
添加一条评论
添加你的答案
frantan13 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 28
总计 275
