跳转到主内容
加入维修社区 - 创建账户
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
LCD replacement difficulty question.
Hello all,
Has anyone replaced only the LCD on one of these models, and if so how difficult is it? I can imagine they're packed quite tightly. There's no necessary destruction is there?
Also, LCDs for either A1237/A1304 are interchangeable right?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
I have not replaced the LCD in one of these display assemblies, but I expect it would be difficult to remove the bezel without damaging it. You have to fight your way through some very sticky double sided tape. If you have not already done so, take a look at the teardown of the MacBook Air Models A1237 and A1304. Step 21 gives a little bit of a hint as to how difficult replacing the LCD may be.
完成的
添加一条评论
2个答案
已选择的解决方案
Here's a video on how to do it. Judge for yourself if this is something you can handle: http://www.powerbookmedic.com/wordpress/...
Here's another one: http://www.youtube.com/watch?v=AMpzI4DMd...
这个答案有帮助吗?
得分 4
1条评论:
Thanks, dosen't look too bad. Just the ubiquitous sticky tape. Always forget that youtube can be informative too.
Second one is for a macbook by the way.
完成的
添加一条评论
I did this one, replacing not the LCD but the lid itself. I thought I was being extremely careful with the LCD Bezel, but I broke the LCD in more than one place in the process of removing the Bezel. The rest of the job was manageable, but breaking the LCD was a disappointment.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ben 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 2,213
