跳转到主内容
加入维修社区 - 创建账户
HP Laptop 14-dk1022wm 是一款紧凑、经济实惠的设备,广泛应用于学生和普通职员的学业、工作及个人用途。
My laptop doesn't login
When I turn on the laptop it stops when the HP logo appears. I tried to format it but also when I restarted it doesn't work again
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
restart it and try again
这个答案有帮助吗?
得分 0
添加一条评论
@younisbamasood so this sounds like a failing boot drive (SSD/HDD). The fact it boots to the HP screen is good because most of the system works up to the point where it hands over to the boot drive.
Hold F2 when starting the PC, choose diagnostics and select hard drive diagnostics. Run the rest and see if it passes.
If you have another computer available, you can create a Linux Live USB and see if it can boot into that.
If yes, the problem should go away once the boot drive is replaced.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Younis Bamasood 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 200
