跳转到主内容
Google Pixel 6 的维修及拆解信息。机器型号为 GB7N6 和 G9S9B16。
All sensors failed after replacing display
This is after my second display replacement. First the audio was muting frequently for a second. It even happened for bluetooth. Then I noticed the proximity sensor failure and then gyroscope and rest. I have even removed and reinstalled the display. Did I miss any connection or my sensors were damaged somehow during the replacement? Pls help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
@mmhebron Hello! A little bit of a long shot, but have you tried factory resetting the phone? Sometimes replacing parts can cause very weird software issues which is what this is sounding like, it's likely to either be that or some form of motherboard damage.
这个答案有帮助吗?
得分 0
4条评论:
Yes, I forgot to mention that. I did reset and nothing has changed. After that I have removed the screen and installed again.
完成的
@mmhebron Ah, unfortunately then the most i can suggest is ensuring that all other connectors are properly seated and that none of the antennas are damaged or deformed!
完成的
Last night I have installed security update 5th August 2023 and everything is working fine. Phone resetting failed, but a 22mb security update fixed it. Wow Google, are you for real? 😒
完成的
@mmhebron Sounds like most tech companies to be honest.... glad it's sorted atleast!
完成的
添加一条评论
I have been facing the exactly the same issue since yesterday. Hope next security update will fix this. Fingers crossed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Moshe Hebron manukonda 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 342
