跳转到主内容
The Dell OptiPlex 360 is a cost effective desktop solution built with practical features focused on providing essential business value.
Motherboard is not working
Motherboard is not working properly
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
What part of the motherboard is not working? Can you give more details of the issue?
完成的
@kumailkazmi you really need to give us lots more information if you expect some help with this. At minimum we need to know why you think that your motherboard is not working properly. What make and model motherboard? What does or does it not do? What have you checked and what have you tried to fix this?
完成的
The fan did not spin
=== Update (09/17/23) ===
完成的
@amiribnmohammed if you need help with this you want to give us all the information. The fan did not spin is just to vague. What does your computer do? It overheats? Did it overheat because the fan didn't spin? Did you replace the fan? What did you check?
The only logical answer based on your question would be : Replace the fan.
完成的
Yes my mother board is not working
=== Update (10/01/23) ===
Yes mother board not working
完成的
添加一条评论
1个答案
最有帮助的答案
might be a power issue with the powerbutton on the case, if so. short the pins using a screwdriver or somethign else
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kumail Kazmi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 307
