跳转到主内容
Released in October 2012, identified by model number CQ58-bf9WM, 1.0GHz AMD Dual-Core Processor C-60.
6 个问题 查看全部
How to reset password
So i’ve found a old laptop deep in my storage room and i’m sure it’s full of old photos i’d like to get off so before i pay someone to get it off id like to try to do it my self. it’s a old laptop i think it’s running windows 8 i saw post on how to open the aso (advanced startup options) and tried goin to command prompt option and it makes me enter a password for my account. looking to reset it without loosing all of my pictures though. thanks!
Update (07/18/23)
also when i try to type in a password in the login screen it says “your pc is offline. please sign in with the last password used on this pc.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Take out the drive, and connect it to a different computer. The process of removing the drive depends on what specific model the laptop is, but generally you remove the bottom, take the drive cover off, and then unplug the drive (there are usually a couple of screws holding the drive down, but they’re easy to remove). Most drives from the last 20 years connect with either SAS or SATA. You can buy a cheap USB to SAS (or USB to SATA) adapter cable on Amazon. Plug one end into the drive, and the other end into a USB port. The drive will show up in file explorer, and you can copy and paste all your videos and pictures to a different device. After that, you can put the drive back in the laptop, and then reset Windows.
这个答案有帮助吗?
得分 1
2条评论:
@oldturkey03 Thanks for the advice!
完成的
@shingle Great Answer!
完成的
添加一条评论
添加你的答案
lolguy1100 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 175
