跳转到主内容
Why isnt my ac working on the left side
My ac only blowing cold air on the right side but the left side is warm and the left side blow power is bad
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
A common reason for this fault is the actuator for the blend doors. On pretty much any reasonably modern car they do not use mechanical doors like they did for years; they use a blend door and an actuator. This is a dash out job on any of these cars, so be prepared to spend a day on this repair. At a shop, this is a $20-50 part, and it's mostly labor.
This is what the part looks like:
If that is not it, you may have an issue with the A/C motor or the resistor on the motor. Start with the blower actuator and work your way down as it sounds like an actuator issue based on the other side working. Now if both sides had an issue I'd be inclined to suspect the resistor or motor under the glovebox.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Arian Myran 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 25
总计 811
