跳转到主内容
加入维修社区 - 创建账户
iPad Pro 11 英寸 (第 2 代) 发布于2020年3月,型号包括A2228、A2068、A2230和A2231。
Using the adhesive tape to reattach the screen - Need help
I am struggling using this this iPad Pro 11" (2018/2020) Adhesive Strips to reattach the screen to the ipad. Has any one done this successfully? I have gone through two sets of tape.
There are no clear step by step instructions on how to apply and use the tape.
Replace the custom cut adhesive strips that secure the front panel to the case compatible with the 11 inch iPad Pro tablet 2018 and 2020 models A1934, A1979, A1980, A2013, A2068, A2228, A2232, and A2233.图片
产品
$5.99
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
What seems to be tripping you up?
完成的
添加一条评论
2个答案
最有帮助的答案
iPad 显示屏组件涂抹粘合剂
这个答案有帮助吗?
得分 2
添加一条评论
Totally remove the screen. Remove any traces of the old adhesive from the frame using either alcohol and a cotton bud or a small scraper type blade. Try and remove any adhesive lumps or strips from the screen by rubbing with your thumb. Apply the tape to the sides, top and bottom of the screen then peel off the protective film from the strips, then reattach the cables and fit the plate and screws. Turn on the ipad and check the screen works correctly then close the screen up. Gently press around the the screen to ensure adhesion of the tape. Personally I use tessa tape. Sometimes running a hair dryer around the edges of the screen to heat up the adhesive helps it stick better.
Good luck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Hermann 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 21
总计 475
