跳转到主内容
Upgrade RAM on late 2011 MacBook Pro
What’s the max amount of RAM I can put into a Late 2011 MacBook Pro? I wanted to upgrade to 16gb. With i5 processor. Also want to upgrade the drive to a SSD. Doing this cause on a budget and can’t afford a new laptop. Not even refurbished. Lol
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
It should be able to handle a max of 16GB. (8GBx2). You may want to just try the SSD alone first and see if the performance is good enough for your needs before you buy the extra memory.
这个答案有帮助吗?
得分 2
1条评论:
Thank you for that. Yeah was thinking just the SSD as well. But was still curious on the max RAM.
完成的
添加一条评论
RAM Type:PC3-10600 DDR3Min. RAM Speed:1333 MHz
Standard RAM:4 GB Maximum RAM:16 GB*
Details:4 GB of RAM is installed as two 2 GB modules, no slots free.
*Apple officially supports a maximum of 8 GB of RAM, but third-parties have determined that this model actually is capable of using up to 16 GB of RAM with two 8 GB memory modules.
这个答案有帮助吗?
得分 2
添加一条评论
Am using 16GB of RAM plus have converted original HD to SSD (1TB) and have removed the CD drive and have added another SSD (1TB). It works good.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
MikeLex6398 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 60
