跳转到主内容
I hear a big noise while driving on asphalt at normal speed ,
my car is equipped with Chinese tires,is that high noise is because of those tires?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
@mahmoudelnems it could be road noise from the tires but it could be other things too. Let us know what that noise sounds like. You need to rule out noise from your wheel bearings and from your drive axles etc. How old are the tires? What have you checked? What vehicle is this?
完成的
添加一条评论
1个答案
It's unlikely that budget tires will make a huge amount of noise at low speeds. If the steering wheel is vibrating at low speeds, and that's what you're referring to, I suggest you balance your tires. A metallic clanging sound might be loose heat shields. I'd suggest you describe the noise in more detail, as well as specify when it happens, etc.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mahmoud El-Nems 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 32
