跳转到主内容
The TI-Nspire CX handheld features a full-color, backlit screen, thin sleek design and includes TI-Nspire rechargeable battery.
Why does my cas keep running over and over again?
My case got in a bit of water and had a few minor bumps then I couldn't open it and was warned to charge the battery. I then charged it but when I turned it on it kept running and running again, I couldn't use it and there were warnings about battery and settings. What do I have to do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Remove the battery immediately!
I'm sorry the calculator mislead you. You should never charge or turn on a device that is wet.
The Nspire is a pain to disassemble completely. There are screws underneath the plastic screen protector where the keys are. You'll need to take a blow dryer and heat up the bezel enough that the glue weakens and lifts up the screen protector. You can see the screws here: https://tiplanet.org/forum/gallery/image...
This teardown guide should help as well: Texas Instruments TI-Nspire CX Defective Button Repair
Remove the circuit board and clean it with isopropyl alcohol. Let it dry for several hours to ensure water isn't stuck under any components.
I would recommend getting a new battery. If you're lucky the calculator will turn on and start working normally. You may need to reinstall the OS but that's not super difficult. I would recommend using the N-link website for that. You can get the latest (non-jailbreakable) OS on TI's website.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Donna 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 182
