跳转到主内容
加入维修社区 - 创建账户
MityVac 出品的 MV8000 系列手动真空泵之一,作为一款维修套件,配备了软管、适配器和储液罐,适用于制动离合器分泵排气等任务。
won't build vacuum when handle released
Hi I just recently bought this pump and for whatever reason it is able to pull vacuum if i hold the handle down but when i release the handle the vacuum restores to no-vacuum - not sure what the issue is - i have disassembled and cleaned the entire unit and no signs of brake fluid or debris. Seals all look new as the unit is brand new with the exception of 1 time use which at that time it worked great - but no brake fluid has been in the gun
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It sounds as if one of the check valves isn't working correctly or for some reason you need to prime it. If I'm not mistaken tho the pump must be hooked up inorder to work and must have at least some fluid in the reservoir to creat and maintain a vacuum.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
dustin kathy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 20
总计 585
