跳转到主内容
加入维修社区 - 创建账户
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
Device Stuck In Recovery Mode
When I plug in the device it will turn on and almost immediately switch to the restore screen. When force restarting the device or turning off the device it will come back on and return to the recovery screen. Using software to exit the recovery screen results in the device boot looping. Ive tried the update and restore options only to be greeted with unknown error 4041. Letting the battery go dead and attempting to restore didn't have any yield either. The device wont enter the debug or dfu mode either.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
Error 4041, or 4014 (I only ask for clarification because 4014 is not uncommon)?
完成的
添加一条评论
3个答案
最有帮助的答案
Had same 4041 error issue on iPhone 13. After multiple attempts, I found related to aftermarket screen. Also experienced while connecting charging cable sometimes intermittent hesitation with phone recognizing cable.
By process of elimination, I swapped back to original screen, then attempted restore/update with success. Also, no more intermittent hesitation when connecting.
Hope this helps someone out there!
这个答案有帮助吗?
得分 4
2条评论:
Thank you! Removing the aftermarket screen worked for me. No more 4041 error. Removed screen & update went through.
完成的
Thanks you, also. I didn't even go back to original screen, just disconnected replacement screen, did restore (successfully), then reinstalled aftermarket screen.
完成的
添加一条评论
4014 is usually caused when your iPhone or iPad cannot create/sustain a connection to your computer. This is mostly caused due to a faulty charging cable. Be sure to try to restore with a few different lightning cables to rule out this possibility. You should also try using an OEM or "Made for iPhone" cable if at all possible to avoid any issues.
If the issue is 4041 and not 4014, you may have a faulty logic board and require microsoldering repair from what I've been able to gather.
这个答案有帮助吗?
得分 1
添加一条评论
how to opned
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Isaac Hurley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 22
过去 30 天: 94
总计 2,906
