跳转到主内容
加入维修社区 - 创建账户
Whirlpool Gold Series 洗碗机可通过型号 WDF750SAYM0、WDF750SAYM1、WDF750SAYM2 或 WDF750SAYM3 进行识别。
Dishwasher won't start
We have a whirlpool gold series dishwasher. On control panel most lights are on but faintly..to start washer I had to push start button twice for it to start..as of yesterday it won't run at all... tried unplugging it for 15 minutes and it still won't run. Any help is greatly appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
If the lights are dimmer than normal, that would indicate a power supply problem. The power supply is part of the control board. The control board is generally located in the door. It is also possible corroded pins on a connector are causing the issue.
Control boards are not cheap (~$200.) so check everything b4 you purchase one.
这个答案有帮助吗?
得分 0
添加一条评论
Hit heated dry and hi temp wash 3 times. All lights are bright. Washer runs for a minute then stops
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ringo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 15
总计 321
