跳转到主内容
The G502 Hero has the same ergonomic design as its predecessor, with an updated sensor. Released in 2018 and identified by model number M-U0047.
Scroller button verso destra stops working with light touches
my "scroller button verso destra" stops working with light touches on occasions and I have to press harder and turning the scroll forward, instead the opposite button works without problems
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sounds like the scroll wheel encoder. I actually just had a similar issue on my G603, here is the guide for that encoder replacement so you can have and idea as to what this entails.
To figure out the exact part you need you may just need to disassemble your mouse and check the part for the wheel encoder. Here is a disassembly guide for the G502 Hero. You may even find that after taking it apart and cleaning it it works again! If not just search Ebay for that part and you should be able to find it.
Logitech G502 Hero Mouse图片
指南
Logitech G502 Hero Disassembly
难度:
中等
1 hour
Logitech G Series Mouse Wheel Encoder图片
指南
Logitech G603 Wheel Encoder Replacement
难度:
简单
10 - 20 minutes
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
JDMys 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 167
