跳转到主内容
Logitech G603 Wheel Encoder Replacement
你所需要的
  1. Logitech G603 Wheel Encoder Replacement, Remove Top Cover & Batteries: 步骤 1 中的图像 1,1
    • Remove magnetic top cover, batteries, and wireless receiver (if currently stored inside the mouse)
  2. Logitech G603 Wheel Encoder Replacement, Remove Mouse Feet: 步骤 2 中的图像 1,3 Logitech G603 Wheel Encoder Replacement, Remove Mouse Feet: 步骤 2 中的图像 2,3 Logitech G603 Wheel Encoder Replacement, Remove Mouse Feet: 步骤 2 中的图像 3,3
    • Carefully remove the feet to reveal the 4 screws holding the top and bottom shells together
    • NOTE: These feet can be removed carefully enough to be reused. Only the top and bottom feet need to be removed, not the one around the sensor
  3. Logitech G603 Wheel Encoder Replacement, Remove the four Phillips #00 Screws: 步骤 3 中的图像 1,1
    • Use Phillips #00 to remove the four bottom screws
  4. Logitech G603 Wheel Encoder Replacement, Separate the Top and Bottom Shells: 步骤 4 中的图像 1,3 Logitech G603 Wheel Encoder Replacement, Separate the Top and Bottom Shells: 步骤 4 中的图像 2,3 Logitech G603 Wheel Encoder Replacement, Separate the Top and Bottom Shells: 步骤 4 中的图像 3,3
    • Start at the top above the left and right click and slowly work your way around the shells until they are separated
    • Be careful not to damage the power connector or ribbon cable going from the top shell's boards/battery to the bottom shell's board
  5. Logitech G603 Wheel Encoder Replacement, Unplug Power and Ribbon Cables: 步骤 5 中的图像 1,3 Logitech G603 Wheel Encoder Replacement, Unplug Power and Ribbon Cables: 步骤 5 中的图像 2,3 Logitech G603 Wheel Encoder Replacement, Unplug Power and Ribbon Cables: 步骤 5 中的图像 3,3
    • Start with the red and black power cable and gently pull it out
    • Once power cable is removed, you should be able to unfold the two halves and unplug the white ribbon cable
  6. Logitech G603 Wheel Encoder Replacement, Remove Encoder Ribbon Cable: 步骤 6 中的图像 1,1
    • Gently pull out the black ribbon cable connecting the encoder board to the main board
  7. Logitech G603 Wheel Encoder Replacement, Remove 5 Phillips #00 Screws: 步骤 7 中的图像 1,1
    • Remove the Phillips #00 screws holding the encoder board in place
  8. Logitech G603 Wheel Encoder Replacement, Remove Encoder Board & Wheel: 步骤 8 中的图像 1,1
    • Remove the encoder board from the bottom shell
    • Gently remove the wheel from the older encoder board
    • NOTE: The old wheel can be reused in the replacement encoder board
结论
另外一个人完成了本指南。
Jim
于06/17/23注册
331 声望
创作了2篇指南
1指南评论
In my case, cleaning the encoder plate in an ultrasonic bath did the trick.
dobromir.dombek - 回复
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 44
过去 30 天: 182
总计 4,773
