跳转到主内容
A1418/EMC3069/2017/3.0GHz四核心Intel Core i5、3.4GHz四核心Intel Core i5或3.6GHz四核心Intel Core i7处理器。于2017年6月8日发布。
176 个问题 查看全部
12 + 16 Pin to 2.5 inch SATA adapter?
Hello, I have a base model 2017 4K iMac, I bought a 12 plus 16 pin drive thinking it had an m.2 slot, of course it doesn’t and it’s too late to return the drive. I’ve been searching all over for adapters but I’m not finding anything. Is there a way I can still use this drive ? I also found an adapter that would convert it into a regular m.2 slot and I’m wondering if I get that adapter and an m.2 to SATA on top of that if the 12 + 16 pin drive will work. Thank you 🙏
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
It's more work than using the SATA but you can plug it in here, if the M2 you got is compatible with a Mac:
iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement
这个答案有帮助吗?
得分 1
添加一条评论
There are external cases which can hold the drive.
I’m not a lover of adapters in iMacs as it’s such a bear to get to the drive and these adapter and drive combos have a much higher failure rate. I had a very full drawer of both adapters and drive’s which died in them. This is not a failure of M.2 drives it’s a bit more to do with the interfaces and forcing something that was not designed to work fully in this setup.
这个答案有帮助吗?
得分 0
2条评论:
I can’t seem to find a 12 plus 16 pin adapter even externally. I messaged some eBay sellers and they said they do not make such a drive.
完成的
@benjilambert - Here’s a useful write up on Apples custom SSDs The Ultimate Guide to Apple’s Proprietary SSDs the 12 + 16 pin drives are Generation 3. As far as external cases OWC was one of the few which had offered on. I doubt they still offer it. There is no demand really for this cases.
完成的
添加一条评论
添加你的答案
Benji Lambert 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 34
