跳转到主内容
加入维修社区 - 创建账户
任天堂于 2011 年 2 月发布的首款 3DS 掌上设备,型号为 CTR-001。
Error message on 3DS
Hello,
I have a Homebrewed 3DS and I have it set up through Sub Wars/Steelhax.
Yesterday, every time I would click on Steelhax to open Homebrew, it would not load and would keep giving me the following error message: “An error has occurred. Please save your data in any software in use, then restart the system."
There was a system update prompt, could that be why? It is now version 11.17.0-50U, if that helps any.
I didn’t have any other software open.
Any help is appreciated, thanks!! :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
11.17 was released specifically to fight CFW and homebrew, so it very well could be the problem. Start with this:
  1. Turn off the console
  2. Hold the SELECT button
  3. Turn on the console while still holding the SELECT button.
If you see something like "Luma3DS Configuration" , head to this page, scroll to the bottom, and follow the link for your luma version.
If you boot to the normal HOME menu, I'd try setting up steelhax again. If you only want homebrew, you can stop after the second page, but I recommend following the guide to the end to install boot9strap + Luma3DS custom fiirmware
这个答案有帮助吗?
得分 2
2条评论:
I don't have a homebrew 3ds how do I get pass the error?
完成的
@devsterpas86589 Could be any number of things causing it. When does it happen? (as in, after doing what?)
完成的
添加一条评论
添加你的答案
Caitlin Lumsden 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 93
总计 3,391
