跳转到主内容
The K-Gro PowerPro is a ridable lawnmower built for K-Mart by MTD and Murray. Released in 1997. Model numbers: 13AL452F120 (38", 12 HP) & 13AQ695H120 (46", 18 HP).
35 个问题 查看全部
It will start but it won't go forward or backward when shifted.
My Power Pro 12 horsepower IC riding lawn mower will not go forward or backward when shifting into gear. It will start and if it's a neutral I can roll it but when I put it into drive a reverse it won't move. Please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@melissajoh96231 first thing to check would be your drive belt since you can roll it. This should help with that
这个答案有帮助吗?
得分 0
3条评论:
The drive belt seems fine. It's not broken and it seems like it fits like it's supposed to.
完成的
@melissajoh96231 when your engine runs is your drive pulley moving? Have you tighten the idler pulley? Does your rear pulley, the one on the drive axle, rotate? WATCH YOUR HANDS AND FACE IF YOU NEED TO GET TO CLOSE TO IT. DO NOT GET HACKED UP BY THOSE BELTS ETC.
完成的
I'll check that out. Thank you!
完成的
添加一条评论
添加你的答案
Melissa Johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 49
